applefanboy's avatar
applefanboy
R9000 — Nighthawk X10 AD7200 transmitting 5ghz but not accepting connections
Hello,
I have a R9000 — Nighthawk X10 AD7200 Smart WiFi Router. The router is transmitting a 5GHz signal but not accepting any connections to it.
So far I have tried:
  1. Installed dd-wrt
    1. Issue persists
      1. flashed back to newest NETGEAR firmware via tftp
  2. Factory reset
    1. Issues persists
  3. Tried various older versions of firmware
    1. Issue persists
  4. Disabling security
    1. Issue persists
  5. Changing channels
    1. Issue persists
As of 20220605 the router is on the newest version of NETGEAR firmware V1.0.5.40. 2.4Ghz is working and hardwired connections are working as expected.
Are there any other options I can try? I am at a loss as to why it started happening...
Thanks.
  • FURRYe38's avatar
    What happens if you disable WPA security on the 5Ghz radio, then does anything get connected? Set WPA2 and AES after testing this.
    • applefanboy's avatar
      applefanboy
      The modem is a Netgear C7000. I attempted to disable security and connect; I am still unable to do so. I also changed the security option and changed the password, same result. I presume it must be a hardware issue at this point.
      • FURRYe38's avatar
        What mode is the C series modem in? Bridge?
        What browser are you using? Try MS Edge or Firefox. Factory reset the router and setup from scratch. Use the configure router yourself option.
        Disable Smart Connect.
        Disable WPA security...can you set this here?
