EddieTnyc
Nov 19, 2020Aspirant
R9000 : Plex server : Not available outside your network
I'm not sure whether this is a Plex issue or a Nighthawk issue, so I'm posting in both community forums.
Does anybody have external access to the Plex server on their Netgear Nighthawk X10 R9000 wireless router?
My router is running Router Firmware Version V1.0.5.24 and Plex version 1.19.5.3112-b23ab3896 Sep 29, 2020. Plex works beautifully in-network; i.e. inside the home. However, I cannot access the Plex server outside of my home network. In the Plex Web App, the server's Remote Access tab says Not available outside your network. The interesting thing is that it shows my Public IP address for both the Private and Public addresses.
I've followed all the Plex troubleshooting guides I could find, and I've confirmed that I'm not having issues with Double-NAT, and I'm not on Xfinity, so I'm not experiencing any xFi issues. I've toggled UPnP off and on, but to no avail. I've also (for kicks) tried manually specifying the default public port. (Of course, since my Plex server is running on the router, I can't forward 32400/TCP to itself.)
Any ideas? I'd love to hear from anyone that has their external Plex configuration working.
I don't have a R9000 but I have used plex for years.
What modem do you have?
have you went through this guide?
https://support.plex.tv/articles/200931138-troubleshooting-remote-access/
- EddieTnycAspirant
Hi plemans, thanks for your reply! Yes, https://support.plex.tv/articles/200931138-troubleshooting-remote-access/ is actually the last article/guide I went through before giving up and deciding to post my question.
With regards to the troubleshooting guide, I've confirmed that UPnP is on (I toggled it off and then on again, just in case). Since my server is the router, itself, I cannot configure manual port forwarding to it. The router does not allow a target of itself for forwarded ports. Because it's the router, it has a static IP address. What I find interesting is that Plex shows both the internal/private and external/public addresses as the same (instead of 192.168.1.1 for internal and the public IP for external). Lastly, when I curl ifconfig.co or hit myexternalip.com or any other public IP reporting site, I get the same IP address assigned to my router's WAN port, so I'm fairly certain I'm not dealing with a double-NAT issue.
I've got a Gig connection on Spectrum; the cablemodem is a Motorola E31T2V1 in bridged mode, if anyone thinks it matters.
I'm really lookig forward to any information that will allow me to access my Plex server media from outside my home network.
Has it ever worked outside of the home?
Have you tried uninstall/reinstall of plex?
