Mtnman1's avatar
Mtnman1
R9000-100NAS
I cant open the VPN license key after setting up the files on my PC. windows 10 how can I get that so I can enter it in the windows VPN set up.
  • Mtnman1 wrote:
    Yes, I did that. I now understand it more with your explanation. Thanks a bunch.
    It can really be a challenge the first time.  I know from experience!
    If this resolved your issue, please mark the thread resolved.
    After you configure your router, you download the Open VPN configuration package.  It is a zip compressed file containing four individual files.
    You have to copy the individual files from the zip package and put them in the configuration sub-directory that is created when you install the Open VPN client application on your PC.
    • Mtnman1's avatar
      Mtnman1
      Ok ya I did all that, but it says there's a network cable unplugged? lol
      • Kitsap's avatar
        Kitsap
        Master
        You cannot test your Open VPN setup with a device that is connected to the same network where the Open VPN server is running.
        If you have a mobile device, you can shut off the Wi-Fi and test through your cell connection.  If you have a laptop and a mobile device, activate the hotspot on your mobile device and connect your laptop through the hotspot.
        On either a mobile device or computer, you have to start the Open VPN application and connect back to the Open VPN server before use.
