perryalbright21
Nov 23, 2025Aspirant
R9000 2.4Ghz & 5Ghz stop working
I had bought this device in January and preconfigured it before we shipped it to a Missionary House in Honduras. The Wifi 2.5 and 5Ghz stopped working and their leds are off. The firmware was update...
CrimpOn
Nov 23, 2025Guru - Experienced User
Maybe someone pressed the button by accident? (page 60 of the User Manual)
https://www.downloads.netgear.com/files/GDC/R9000/R9000_UM_EN.pdf
- perryalbright21Dec 01, 2025Aspirant
Working with technical support team and it has a hardware failure inside of the unit.
- FURRYe38Dec 02, 2025Guru - Experienced User
Something you can do, disable the wifi radios on the router and install a external ethernet connected wifi AP.
Good Luck.
