perryalbright21
Nov 23, 2025Aspirant
R9000 2.4Ghz & 5Ghz stop working
I had bought this device in January and preconfigured it before we shipped it to a Missionary House in Honduras. The Wifi 2.5 and 5Ghz stopped working and their leds are off. The firmware was update...
perryalbright21
Dec 01, 2025Aspirant
Working with technical support team and it has a hardware failure inside of the unit.
Dec 02, 2025Guru - Experienced User
Something you can do, disable the wifi radios on the router and install a external ethernet connected wifi AP.
Good Luck.
