TamHuynh's avatar
TamHuynh
Follower
Apr 21, 2017
R9000 power adapter needed
My netgear R9000 power adapter was get burned. So I am looking for a new adapter. Please help me
  • netghear wrote:
    Call support for replacement if within warranty.
    Definitively yes!
    Should the hardware warranty be obsolete (why ever), you can consider these standard universal notebook power supplies19 V, rated for 60 or 65W at least - these are much easier to get than specific power supplies, the prices came down massively the last year or so.
  • Call support for replacement if within warranty.
    The adapter same as the R8500. Have you tried ebay or google the part number.?
    • schumaku's avatar
      schumaku
      Definitively yes!
  • JamesGL's avatar
    JamesGL
    NETGEAR Employee Retired
    Hi TamHuynh,
    You can purchase power adapter with the same specs for your R9000. Check the Input and Output specs of the current adapter.
