crazycasey
Sep 11, 2025Aspirant
R9000 stopped producing 2.4ghz & 60ghz - crashes rapidly after connecting to 5G
Hello, I have a nighthawk x10 R9000, firmware 1.0.5.42. This has been running issue free for 5years plus, I suspect hardware repair is required. It has stopping being able to produce the 2.4g...
Sep 11, 2025Guru - Experienced User
Might give a 30-30-30 reset and see if this changes anything.
Manually reload FW again. Also give Voxels FW a try as well as he is carrying on with FW updates for the R9000 since it's EoL with NG official FW.
If all this doesn't change anything, router may need to be replaed, OR, disable ALL radios on the router and install a external wifi system in AP Mode, something like a Orbi or Nighthawk MESH system or any wifi AP that can be ethernet connected to the R9000.
crazycasey
Sep 12, 2025Aspirant
Got a parts list to start throwing at it?
- FURRYe38Sep 12, 2025Guru - Experienced User
No. Nothing that can be repaired. Unless you have deep dive equipment. NG doesn't offer repairs either.
