partlow
Sep 29, 2023Aspirant
R9000 To get three Months Free Plex pass promotion code click "here" is not working
I have a R9000 — Nighthawk X10 AD7200 Smart WiFi Router Under the Plex Media Server button there is: "To get three Months Free Plex pass promotion code click here" Well "here" does nothing. I ...
- Oct 02, 2023
I believe the OP as found absolution in Voxels FW.
The EoS web site seems out of date and needs updating.
Sep 29, 2023Guru - Experienced User
That campaign and offering was enabled years ago and has long been expired. Something you'll need to avoid trying to use.
- partlowSep 29, 2023Aspirant
You think they would remove that with a firmware update.
Why do I need to avoid it?
- FURRYe38Sep 29, 2023Guru - Experienced User
Cause it's not longer working or supported. Even the R9000 is EoL.
You can load up Voxels FW on your R9000 for more up to date FW. I have his loaded on mine.
