partlow
Sep 29, 2023Aspirant
R9000 To get three Months Free Plex pass promotion code click "here" is not working
I have a R9000 — Nighthawk X10 AD7200 Smart WiFi Router Under the Plex Media Server button there is: "To get three Months Free Plex pass promotion code click here" Well "here" does nothing. I ...
- Oct 02, 2023
I believe the OP as found absolution in Voxels FW.
The EoS web site seems out of date and needs updating.
Sep 29, 2023Guru - Experienced User
That campaign and offering was enabled years ago and has long been expired. Something you'll need to avoid trying to use.
partlow
You think they would remove that with a firmware update.
Why do I need to avoid it?
- FURRYe38Sep 29, 2023Guru - Experienced User
Cause it's not longer working or supported. Even the R9000 is EoL.
You can load up Voxels FW on your R9000 for more up to date FW. I have his loaded on mine.
- KitsapSep 29, 2023Master
FURRYe38 wrote:Even the R9000 is EoL.
I am curious. What list are you looking at that shows the R9000 as EoL?
- michaelkenwardSep 30, 2023Guru - Experienced User
Some people have a hot line to the almighty.
It certainly doesn't feature here:
NETGEAR End of Service | NETGEAR
