sergio_fucchi
Apr 28, 2018Guide
R9000 unable to see and manage in my ReadyCLOUD web page.
Hello. I own an R7000, an R8500 and an R9000. The R7000 now uses it as a wifi bridge in my home network, but a few years ago it was my router with which I registered in MyNetgear and ReadyCLOUD. I ha...
- May 10, 2018
Problem solved after installed fw. ver. 1.0.3.16
sergio_fucchi
May 01, 2018Guide
As I have written I have latest version of the firmware and I see and manage usb stick into ReadyCloud section in web page of the router setup.
schumaku
May 01, 2018Guru - Experienced User
sergio_fucchi there is no "latest" firmware. Community content remains visible for a longer time, too. For some users, 1.0.2.x is the latest, for some 1.0.3.10, for others 1.0.3.16.
- sergio_fucchiMay 01, 2018GuideAny router has its own firmware and when I say "the last" this is the last! If you haven't understand the last firmware is when you try to update it and the page say to you that there is not any to update. Ok??
- schumakuMay 01, 2018Guru - Experienced User
sergio_fucchi wrote:
Any router has its own firmware and when I say "the last" this is the last! If you haven't understand the last firmware is when you try to update it and the page say to you that there is not any to update. Ok??Not OK. Appears you are living on a very small planet. Let's hope the Netgear moderators have some more patience with ignorants. Hard to provide assistance with ReadyCloud issue if there would be some more questions requiring different answers then "the last" mi dispiace.
- sergio_fucchiMay 01, 2018GuideI do not live in a small planet if I assume that those that support or help to solve problems understand who says they have the latest version of the firmware installed. If you are aware of Netgear products, you should have no difficulty knowing which version of a Netgear router is the latest version of a firmware. Perhaps, however, my interlocutor does not work in Netgear and he does not want to search the Netgear site so I specify that the latest version of the firmware of my R9000 is 1.0.3.10. I hope this is relevant to the solution of my problem. Thank you.
