Ra-Dzik's avatar
Ra-Dzik
Apprentice
Dec 10, 2022
R9000 (V1.0.5.42) - 2.4GHz disappear(!)
Recently I have noticed that despite the 2.4GHz Wi-Fi feature being enabled (it is always on), this frequency shuts down/loses itself, even though it is enabled in the firmware. Surveillance cameras are just connected on 2.4GHz and once a week or more suddenly this frequency shuts down on its own.
Only turning off 2.4GHz and turning it back on in the firmware helps.
Do you have similar problems?
  • FURRYe38's avatar
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    How many devices do you have connected to the router?
    What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch.
    • Ra-Dzik's avatar
      Ra-Dzik
      Apprentice
      I think you read my post very cursorily and without understanding it!
      What does Cat6 cable have to do with Wi-Fi?
      You write about channels for 5GHZ frequency and I write about 2.4GHz - I write "about head" and you reply "about".
      What has ONT and ISP provider to do with local 2.4GHz network and problems of disappearing network at this frequency!
