Johnny54321
Feb 10, 2018Aspirant
R9000 WiFi On/Off button OPENS WiFi to the Public, HUGE Security Flaw!
Nighthawk X10 R9000 Router Firmware Version V1.0.3.6 WiFi is configured to use WPA2 Security. Pushing the WiFi On/Off button for 3 seconds turns of the Button LED, and the Antenna LED's, and Shows ...
- Feb 27, 2018
Hi Johnny54321,
Can you check this firmware.
https://kb.netgear.com/000055126/R9000-Firmware-Version-1-0-3-10
I tried to reproduce the problem with my R9000 but it works fine.
Feb 19, 2018Guru - Experienced User
Someting to get ahold of one of the Forum moderators about and ask them for help and info regarding this.
I presume your FW is up to date? Make sure it is.
You might try Voxels R9000 FW. It uses same UI, however back end stuff is better managed.
https://www.voxel-firmware.com/Downloads/Voxel/html/r9000.html
Might give this a try, if same thing still happens then the core NG code would need to be looked at by NG.
