Johnny54321
Feb 10, 2018Aspirant
R9000 WiFi On/Off button OPENS WiFi to the Public, HUGE Security Flaw!
Nighthawk X10 R9000 Router Firmware Version V1.0.3.6 WiFi is configured to use WPA2 Security. Pushing the WiFi On/Off button for 3 seconds turns of the Button LED, and the Antenna LED's, and Shows ...
- Feb 27, 2018
Hi Johnny54321,
Can you check this firmware.
https://kb.netgear.com/000055126/R9000-Firmware-Version-1-0-3-10
I tried to reproduce the problem with my R9000 but it works fine.
JamesGL
Feb 27, 2018NETGEAR Employee Retired
Hi Johnny54321,
- Johnny54321Feb 27, 2018Aspirant
That update solved it!
Now, it all works just fine.
To recap, I have WPA2 Security on my WiFi Broadcast, and now, when I push the WiFi button on the router, it turns the WiFi On/Off, where as with the previous update, pressing the button would turn On/Off the WPA2 Security and be wide open to the Public.
Thank You!
- JamesGLFeb 28, 2018NETGEAR Employee Retired
Hi Johnny54321,
I am glad to know it works. :)
