Johnny54321
Feb 10, 2018Aspirant
R9000 WiFi On/Off button OPENS WiFi to the Public, HUGE Security Flaw!
Nighthawk X10 R9000 Router Firmware Version V1.0.3.6 WiFi is configured to use WPA2 Security. Pushing the WiFi On/Off button for 3 seconds turns of the Button LED, and the Antenna LED's, and Shows ...
- Feb 27, 2018
Hi Johnny54321,
Can you check this firmware.
https://kb.netgear.com/000055126/R9000-Firmware-Version-1-0-3-10
I tried to reproduce the problem with my R9000 but it works fine.
JamesGL
Feb 27, 2018NETGEAR Employee Retired
Hi Johnny54321,
Johnny54321
Feb 27, 2018Aspirant
That update solved it!
Now, it all works just fine.
To recap, I have WPA2 Security on my WiFi Broadcast, and now, when I push the WiFi button on the router, it turns the WiFi On/Off, where as with the previous update, pressing the button would turn On/Off the WPA2 Security and be wide open to the Public.
Thank You!
