Netcruizer's avatar
Netcruizer
R9000 with SFP+ as WAN port
Dear Community and Gurus,
Has anybody actually got more than 1gbps combined on all open LAN ports, downloading concurrently, of R9000 when SFP+ is connected as WAN to a fiber 10gbps connection?
To clarify. If say 4x LAN ports are connected to 4 independent PC's downloading 4 streams concurrently, a combined 4gbps is achieved over the 4 LAN ports.
Reason for my asking: I have a lot of respect for Netgear engineers. So I got annoyed when somebody told me that it is not possible because of the constraint on the internal switches of R9000. Unfortunately, I do not have a 10gbps Internet connection to verify.
Thank you in advance.
  • FURRYe38's avatar
    The LAN ports on the R9000 are max rated at 1Gb each so each PC should see just over 900Mpbs. Will not see anything over 1Gb on the LAN ports.
    • Netcruizer's avatar
      Netcruizer
      Thank you kindly for your reply.
      But it's not clear to me from your answer.
      1. That 3.6 Gigabits of data in total, i.e. 4 times x 900Mbps, would arrive at 4 PCs (that are concurrently downloading from LAN ports of R9000) after 1 second of time with SFP+ as WAN port?
      2. If the above result is obtained from your actual SFP+ WAN connected to an ISP fiber connection of 10Gbps, would you be so kind provide some proof for it?
      In other words, can you validate Netgear's claim of:
      • Up to 10G speeds on standard RJ45 cables
      when using R9000's SFP+ for wide area network (WAN) connectivity. See:
      https://kb.netgear.com/000060605/How-do-I-set-up-my-10G-SFP-port-for-WAN-on-my-NETGEAR-Nighthawk-R8900-or-R9000
      Thank you for your help in this matter. With respect.
      • FURRYe38's avatar
        I would presume that if the ISP side of the SPF port was at 10Gb connection rates, that if you had four 1Gb connected PCs connected to the 1Gb LAN ports in back, each one could see near or just over 900Mpbs on each PC while testing all at the same time.
