rbport
Mar 19, 2018Tutor
R9000 WPS button location
This may seem a stupid question but I can't find the WPS button in the router and the user manual doesn't mention its location as well.
Anyone can help?
Thank you in advance.
> Btw, another question that I can't see amswered in the manual: all the
> LED lights in the front are white with one exception, which is orange
> for one of the ethernet cables.
Page 12:
Ethernet ports 1-4
The LED color indicates the speed: white for Gigabit
Ethernet connections and amber for 100 Mbps or 10 Mbps
Ethernet connections.
So, an amber LED indicates that that Ethernet LAN port is connected
to a slow (slower than gigabit) device. It could be some old/slow
device, or it could be a gigabit interface on a device which is in
standby ("off" or sleep) mode, where its gigabit interface is
artificially slow, waiting for normal operation before it changes to
gigabit speed. (Or, a defective cable.)
My ignorance of what's at the other end of that cable limits what
more I can tell you.
Read more carefully? Look for "WPS button with LED" (near "WiFi
On/Off button with LED", page 13). A close examination of the router
should reveal that the two rightmost LED indicators are not simple LED
indicators.
Some of the User Manuals make this clearer than others. See, for
example, the D7000 User Manual (page 13).
The other, related question goes something like, "I moved my router,
and now the wireless stuff doesn't work." The questions are a little
stupid, but I'd put much more blame on the documentation, which shouldbe noisier about these crypto-buttons.
- rbportTutor
Thanks a lot! I hadn't noticed that those 2 buttons were different and in fact the user manual isn't clear enough about it.
Btw, another question that I can't see amswered in the manual: all the LED lights in the front are white with one exception, which is orange for one of the ethernet cables. Do you know the reason for this situation?
Page 12:
Ethernet ports 1-4
