Westyty
Sep 01, 2026Aspirant
RAX30 firmware update to V1.0.14.108_1 fails — stuck on V1.0.13.102_2
Hi everyone, I'm having trouble updating my RAX30 firmware and hoping someone here has run into the same issue. Current firmware: V1.0.13.102_2 Update offered: V1.0.14.108_1 (security bug fix accor...
Sep 01, 2026Guru - Experienced User
And you unpacked the FW file from the .zip file after it was downloaded?
Using MS Edge or Firefox browser?
Westyty
Yes, I unpacked the .chk file from the .zip before uploading it manually.
I used Google Chrome to perform the update
- FURRYe38Sep 02, 2026Guru - Experienced User
Try using MS Edge or Firefox browser?
What happens if you downgrade the router back to first version of FW then after, apply this latest version of FW?
