netoperator
Dec 09, 2020Aspirant
before you buy
Greetings Ladies and Gentlemen, If I want to buy-- and install-- a router for computer and smartphone. What do I need to buy ? Thank you
schumaku
Dec 09, 2020Guru - Experienced User
PauLita wrote:Neither Ladies, nor Gentlemen need anything to buy to connect their smartphones to internet.
Also the computer can be linked up with the smartphone.
netoperator you need to provide more details for your plan. Of course, Netgear, your mobile operator, or any other router maker will be happy to offer some addiitonal hardware solutons.
Netgear's offerings are here:
4G/5G WiFi Routers Equally good for home, SOHO and a smaller SMB out there in the no-wired-Internet areas.
4G/LTE Modems Of course not a modem as no analogue modulation and demodulation, technically a bridge. The modem term is misleading anaway, it can serve (and does out of the box) as a NAT router for wired Ethernet. It can be used as a router in combination with a switch and a wireless access point, or in bridge mode to connect your WiFi router or Mesh system of choice.
PauLita
Dec 09, 2020Luminary
Or:
