byteme67
Jun 11, 2018Tutor
Cannot access routerlogin.net
I believe I am pretty tech savy when it comes to issues like this. But I've exhausted all avenues other than spending good money on something that should just typically plug in and "poof" we are work...
antinode
Jun 11, 2018Guru
What, exactly, happens when you try?
> [...] The IP address I am getting looks to be one directly from the
> modem.
What is that "The IP address I am getting"? Determined how, exactly?
If it really is your public IP address, then disclosing the first two
octets ("a.b" out of "a.b.c.d") will do.
As usual, showing actual actions with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.
> [...] the computer [...] Windows Firewall [...]
Open a Command Prompt (CMD.EXE) window, and run an "ipconfig"
command. Report the "IPv4 Address", which should be the address of your
computer, and the "Default Gateway" address, which should be the address
of the router. (Copy+paste is your friend, but not a strict requirement
in this case.)
> 9) and anything else that might make it work did not work.
"did not work" is not a useful problem description. It does not say
what you did. It does not say what happened when you did it. As usual,
showing actual actions with their actual results (error messages, LED
indicators, ...) can be more helpful than vague descriptions or
interpretations.
> 10) disconnected modem from router just to be able to have access only
> to router did not work. [...]
That should work, if the R7000 is in its default (full-router) mode,
which it should be after a setting reset. What, exactly does "using the
modem reset button" mean to you? Did you hold it down long enough to
get unusual LED indicator activity?
> [...] Did not even get an IP address from the router.
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual. Read. What are your LED
indicators doing through all this fun?
byteme67
Jun 11, 2018Tutor
I get this message: You are not connected to your Router’s WiFi network. To access routerlogin.net, your device must be connected to your Router’s WiFi network. Check your current connection and try again.
What is that "The IP address I am getting"? Determined how, exactly? I use the CMD.EXE and type the command IPCONFIG. Poof there it is. If it really is your public IP address, then disclosing the first two octets ("a.b" out of "a.b.c.d") will do. The IPv4 IP address is 76.101.xxx.xx. My Default Gateway is 76.101.xxx.x
Open a Command Prompt (CMD.EXE) window, and run an "ipconfig" command. Report the "IPv4 Address", which should be the address of your computer, and the "Default Gateway" address, which should be the address of the router. (Copy+paste is your friend, but not a strict requirement in this case.) I posted the IP addresses above.
"did not work" is not a useful problem description. It does not say what you did. It does not say what happened when you did it. As usual, showing actual actions with their actual results (error messages, LED indicators, ...) can be more helpful than vague descriptions or interpretations. This is a sarcastic remark!
That should work, if the R7000 is in its default (full-router) mode, which it should be after a setting reset. Theoretically YES you're right it should!! But it doesn't!! What, exactly does "using the modem reset button" mean to you? Factory Reset any and all settings should be defaulted back to original out of the box state. Did you hold it down long enough to get unusual LED indicator activity? Yepper count to 10 or when the light goes out and back on again. sometimes even longer which would be a moot point but still.
Determined how, exactly? Through the CMD.exe prompt and using the command IPCONFIG. The typical IP address of any router is 192.168.0.1 or 192.168.1.1. That does not happen in my case for the Default Gateway. I mean I do get an IP address but I believe that is the IP address from the provider ("ComSUCKScast"). They seem to like to still control your stuff even though you BUY your own stuff.
Visit http://netgear.com/support , put in your model number, and look for Documentation. YEP!! I have I wouldn't have posted here if I got an answer from reading and doing the necessary steps to get to this point!! Get the User Manual. Read. What are your LED indicators doing through all this fun? Blinking, flashing, staying solid. Lighting up like a Christmas tree but only with fewer colors!! (sarcasam added). Look I know your answered and are trying to help although "vague" yes, I did list all the steps I have taken in order to clear this issues. They may not be in that order but I have done them.After all this I am going to just take it back! This is ridiculous. Thanks for the help anyway. ("not being disrespectful") Just frustrated that something SOOOO simple should not take hours to correct and make it work. I have set up dozens of routers of all makes and models and this one has proven to be a disaster.
