MechWarriorZero
Jan 03, 2026Aspirant
Re: Can't Map Network Drives in Windows XP
<redacted link> sorry its been a long time, here is my new issue
MechWarriorZero
Jan 11, 2026Aspirant
I couldn't post the image it was not uploading to post it, so I need the link to stay in the post
- StephenBJan 11, 2026Guru - Experienced User
Well, if you put it back make sure the permissions are set up so anyone with the link can download the file (without having to request access from you).
And please start a new discussion thread.
- MechWarriorZeroJan 12, 2026Aspirant
I did set the permissions to view the file not download it
- StephenBJan 12, 2026Guru - Experienced User
I clicked on your link, and would have needed to contact you to get permission to access the file.
I suggest allowing anyone with the link to access (view and download) the file.
I tried that and its not uploading it
Yes, copy paste and using the camera icon don't work for images. Neither does the paper clip.
You can of course just tell us what your problem is.
