MechWarriorZero
Jan 03, 2026Aspirant
Re: Can't Map Network Drives in Windows XP
<redacted link> sorry its been a long time, here is my new issue
MechWarriorZero
Jan 12, 2026Aspirant
I did set the permissions to view the file not download it
Jan 12, 2026Guru - Experienced User
MechWarriorZero wrote:I did set the permissions to view the file not download it
I clicked on your link, and would have needed to contact you to get permission to access the file.
I suggest allowing anyone with the link to access (view and download) the file.
MechWarriorZero wrote:I tried that and its not uploading it
Yes, copy paste and using the camera icon don't work for images. Neither does the paper clip.
You can of course just tell us what your problem is.
