MechWarriorZero
Jan 03, 2026Aspirant
Re: Can't Map Network Drives in Windows XP
<redacted link> sorry its been a long time, here is my new issue
CrimpOn
Jan 12, 2026Guru - Experienced User
Select the menu symbol to insert/edit a link. Past the link to the file in the box.
After YEARS of simply pasting images into posts, the loss of this feature is really annoying. I'm hoping now that the holidays and weekend are over, someone will undo whatever change was made to the Forum software that caused this problem.
