Jmvlg
Jul 16, 2024Aspirant
Re: New - R8000 Firmware Version 1.0.4.88 Released - Hot Fix
Hi, I have v1.4.4.94; is this version older than the one you are providing on your post? I click check updates and always states it’s up to date… thanks
I don't see v.94 in there download list. This is for the R8000. You tagged a R8000P?
- JmvlgAspirant
Correct, I am referring to R8000P. Sorry about that... either way, I never saw an update coming in... is the v.1.4.4.94 the very latest one? Anyone having issues with Wifi turning off&on and/or WiFi router name disappearing from Apple devices? Thank you
Jmvlg wrote:
Hi, I have v1.4.4.94; is this version older than the one you are providing on your post? I click check updates and always states it’s up to date…The "check for updates" feature is unreliable.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Look for the model number on the label on the device.
That page will also have any software, firmware and drivers for your device, if they exist.
There is a library there of all the firmware releases for your router.
