ijankrom's avatar
ijankrom
Nighthawk X6 AC3200 R8000 Content Filtering Question
Is there a way to identify which word (from the content filtering list) the router is hitting on to block websites/services?  Some backend log or something like that?   Description of my issue: ...
  • IrvSp's avatar
    Jun 17, 2018
    I can't answer your specific question, but there is a fast way to find the work, assuming you were going to try it one by one.
    Lets say you have 100 words. First thing to do, save the settings so you can restore them all at any time.
    Next remove 1/2 and test. Still a problem, it is in the other half. Restore and remove the other half and test to verify.
    Next restore all and remove 1/2 of those that were in the failing test and retest. Again, didn't fail, restore and remove the other half and retest to verify.
    Eventually by removing 1/2 and discovering which half has the problem, restoring and cutting in 1/2 again and test you'll figure it out.
    Should be faster than one by one removal.
