gmsaylor's avatar
gmsaylor
Follower
Jan 19, 2018
Nighthawk x6s AC3000 compare to Nighthawk x8 AC5000
I am trying to decide which of these two routers are superior technically.  They seem almost identical except the x6s says it has 6, external, high performance, amplified antennae, and the x8 says it...
  • William10a's avatar
    Jan 20, 2018
    The x6s and the x8s are both good routers the x6s like you said will give you a faster network connection too a computer or nas device as long they can access both network cables to enable it unlike the x8s which uses a external hard drive to store information via a usb connection, the x6s would be a better choice if storage is important to you.
    Dlna is for movie and video steaming then the x8s may fit better if that's what you are into.
    Either would do in must cases all depends on what you want to do.
