BillClinternet
Apr 03, 2022Apprentice
R7000 and R8000 Drops, Loss, Jitter, and all of the above.
I have been through hell and back with these routers. I started off flashing DD WRT after having issues with dropped packets or slow connection especially after being connected overnight. Everything w...
- Apr 09, 2022New modem and the line was checked and everything was working normally. I’ve figured out what the cause of the issues is. 1. The loss is caused by interference on my 5G Wi-Fi, due to netgear not having automatic channels for 5G I have to constantly switch it myself. 2. The bad speed and loss after being connected overnight is 100 percent a software issue and has been resolved by a hard reset but will come back like it always has. My conclusion is what was said before, avoid netgear equipment unless it’s newer models but after this experience I don’t want to deal with anything netgear ever again. The only thing that’s consistent with netgear is how every support person is persistently blaming the ISP or modem, I suppose the easiest route is to blame the other person.
BillClinternet
I will check if ipv6 is enabled but I’ve gone through everything and also researched a lot. I use QOS quite often and turn it off when I want the fastest downloads. I know for a fact all of those settings are correct.
BillClinternet
Sorry for the spam also wanted to add that I’ve tried all the channels for Wi-Fi and no luck. The reason I switched to dd wrt was to reduce the transmit power and have automatic channels for 2.4 and 5G signals.
