BillClinternet
Apr 03, 2022Apprentice
R7000 and R8000 Drops, Loss, Jitter, and all of the above.
I have been through hell and back with these routers. I started off flashing DD WRT after having issues with dropped packets or slow connection especially after being connected overnight. Everything w...
- Apr 09, 2022New modem and the line was checked and everything was working normally. I’ve figured out what the cause of the issues is. 1. The loss is caused by interference on my 5G Wi-Fi, due to netgear not having automatic channels for 5G I have to constantly switch it myself. 2. The bad speed and loss after being connected overnight is 100 percent a software issue and has been resolved by a hard reset but will come back like it always has. My conclusion is what was said before, avoid netgear equipment unless it’s newer models but after this experience I don’t want to deal with anything netgear ever again. The only thing that’s consistent with netgear is how every support person is persistently blaming the ISP or modem, I suppose the easiest route is to blame the other person.
BillClinternet
Apr 06, 2022Apprentice
There’s a good amount of interference in my area and for some reason netgear doesn’t allow auto 5g channels and I can only change broadcast power on my r7000.
BillClinternet
My gaming pc is wired straight to my main router. Never had issues and Speedtest always hits max instantly. I’ve concluded it’s not my modem or main router. It appears to be a netgear software issue and lack of customization in their software.
- BillClinternetApr 07, 2022ApprenticeJust ordered a new modem from spectrum so I’m about to find out for sure if that’s the issue in a couple days. Also probably going to downgrade my access points firmware to 1.0.4.68.
- BillClinternetApr 09, 2022ApprenticeNew modem and the line was checked and everything was working normally. I’ve figured out what the cause of the issues is. 1. The loss is caused by interference on my 5G Wi-Fi, due to netgear not having automatic channels for 5G I have to constantly switch it myself. 2. The bad speed and loss after being connected overnight is 100 percent a software issue and has been resolved by a hard reset but will come back like it always has. My conclusion is what was said before, avoid netgear equipment unless it’s newer models but after this experience I don’t want to deal with anything netgear ever again. The only thing that’s consistent with netgear is how every support person is persistently blaming the ISP or modem, I suppose the easiest route is to blame the other person.
