DrXtreme
Dec 11, 2016Tutor
R7300 DST, QOS, Automatically update performance optimization database fails
Is there a setting that I need to change to get the QOS database update to work? When I click "Update Now" to check for new data it returns "Attempting to connect to Netgear Server. Please Wait..."...
ElaineM
Dec 28, 2016NETGEAR Employee Retired
DrXtreme The firmware you received does not contain the security vulnerability fix. The latest firmware released on this site fixes that.
scoobygolfer
Mar 19, 2017Aspirant
I'm having same issue and need the firmware beta to fix the problem so I can update the performance QOS database. ElanieM can you send to me?
