Arcticcatf7
Dec 25, 2016Aspirant
r7800 will not connect to internet
I'm trying to set up my new router and when going through the set up the internet light turns white. I then go in and try to set it up on either my hard wired computer or from my phone and it goes to...
- Dec 26, 2016
I just did a bunch of searching Charter internet not working for new router and found a solution. Turn everything off and restart the modem. Then press and hold the router power and reset buttons at the same time. Allow it to do its thing then the interent came up and is working prefectly now. Was able to go through the router set up and finsih it.
BoDEAN
Dec 26, 2016Apprentice
What firmware version are you using?
Did you follow the install instructions? I believe it says to turn off the modem, then turn on the router, let it bootup, then turn on the cable modem.
- Arcticcatf7Dec 26, 2016Aspirant
According to the quick start it says to unplug and then plug the modem back in. Then you connect the cable to the router and then turn the router on. How do I check which firmware it has if I can't get it to set up?
