mchensky
Oct 31, 2017Aspirant
R8000P dropping wifi connection
Hello, I own a Nighthawk X6S (R8000P) and I've been having an ongoing issue where after I've been surfing via wifi for some time the wifi connection will remain active however there is no data up/dow...
- Jun 11, 2018
So I updated to Firmware V1.4.0.10 5 days ago. So far no internet drops :smileyhappy:
Haven't tried installing my USB hardrive to see if network storage works again. Just updating everyone.
TerryPh
Jan 06, 2018Virtuoso
Hi. sheikh73.
Sorrry that you could not get this router back to work. In the interest of getting some light into it, I wonder:
1. Did you get to ping sucessfully 192.168.1.1 address before running tftp2 software (by command run, cmd, ipconfig, and ping)?
2. What was the DNS configuration before you ran tftp2 software?
3. Did the amber power LED still stay amber solidly even after trying tftp2?
Worst case scenerio, if you bought this router within a year, you can call customer support and elevate the case to hardware failure, and very possible that Netgear will swap you a new one.
sheikh73
Jan 06, 2018Aspirant
Hi Terry
I don't know how but after pressing the reset button numerous times and many different other methods router restarted by itself. Tftp2 didn't flash the firmware, I was getting ping on 192.168.1.1 but after router rebooted, I got my old configuration back with 10.0.0.1 IP address and old password as well. This Netgear router is funny. I had no hopes and it came back to life by itself.
I have reflashed it and also factory defaulted as well. So far it's working as normal.
Thanks for your help.
Rashid
Rashid
- TerryPhJan 06, 2018VirtuosoHi Rashid,
It's good now that you have a working router. Really to save yourself a headache, if you can get to router interface and see any firmware in your router different than v.1.0.3.54, please downgrade to this version. At present time, this version seems most certainly stable, as I have been trying everything else, including the beta versions that NETGEAR engineer sent to me. The latest beta version just tested yesterday and today to no good working one. And I think I had pretty much idea what was causing the whole fiasco with newest firmware, in general.
Just stay with older version 1.0.3.54 until they figure it out. Don't touch the newest versions 1.0.4.4.x.x.x... you will get into problems soon with it.
Best - drobertJan 07, 2018Aspirant
How do I get back to the order firmware version (1.0.3.54) so I can re-install that? I upgraded to firmware version 1.0.4.4 and starting having problems everyone else has been posting.
- windsagaJan 07, 2018NETGEAR Employee Retired
Hi Terry,
You recommand FW version is R8000 not R8000P.
- TerryPhJan 07, 2018VirtuosoYeas. Just found out. For R8000P, the older Fw 1.3.0.4 or 1.2.1.6 .
- DjRiDeJan 08, 2018Apprentice
Just to confirm:
Firmware: R8000P-V1.3.0.4_1.1.96
Is a good firmware to revert back to and should have no internet drops again? I been reading two different post and one says the above and another says to go to R8000P-V1.2.1.6_1.1.86
I just updated to R8000P-V1.3.0.4_1.1.96 but i wanted to confirm so I conclude my testing to decide if I will keep the router or return. Dont have much time left in my return period.
I appreciate your help!
- windsagaJan 08, 2018NETGEAR Employee Retired
Hi DjRiDe, May I know which FW let the internet drop . v1.3.0.8 ? or v1.3.0.4 ?
You may try to rollback to v1.2.1.6 after data capture.
Thanks
- DjRiDeJan 08, 2018ApprenticeHello,
I know v1.3.0.8 dropped after 3 days. I just bought the router less than a month ago and I didn't look to see what firmware the router was on before I upgraded. So I wasn't really sure which to revert back to. Currently just reverted back to: v1.3.0.4
Thx - DjRiDeJan 10, 2018ApprenticeUpdate::::
1.3.0.4 - still needs rebooting every three days.... I just loaded the previous firmware now. Looks like I will be strongly considering returning for a linksys or asus compatible....
Previous Reply::::
I just updated to R8000P-V1.3.0.4_1.1.96 but i wanted to confirm so I conclude my testing to decide if I will keep the router or return. Dont have much time left in my return period. - TerryPhJan 10, 2018Virtuoso
Hi DjRiDe.
I do understand your decision to return and consider getting asus or linksys router, after many headaches that you went through. Btw, I am also a favorite user of asus routers in the past, but I also like Netgear due to their solid hardware and stability in the past. I think Netgear recently tries to update most of their newer router models and this cause lots of problems. I myself had many days of headaches with my R8000 router which has been stable prior to updating to new firmware in early December last year.
Since then, I reversed back to the old stable firmware version and the router works flawlessly with some minor inconveniences.
Last straw for you, if you do not mind, is to reverse to earlier FW version, may be v1.2.1.6 or earlier v1.1.4.6 for your R8000P or any version that DOES NOT involve Disney Circle (parental control) feature, because I suspect that this feature more likely causes the problems with USB connection, internet connection instablility and a host of other problems involving DNS server etc.
Let me know if you really want to downgrade again and give it few days more before you return the product. And that is totally understandable..
Hi Terry,
On my R8000P I updated this morning to:
Firmware Version
V1.2.1.6_1.1.86I'm a little skeptical in keeping it though. This is my first netgear router - always had linksys in the past. My house recently having more and more smart devices throughout that why I went with this router to have a stable connection for all my tv's, thermostats, doorbell, camera's and all personal devices. I wanna say there's probably at least 30 things connected to wifi in my 3000 square foot (2 story) house. Like I said when this router is working its amazing! Just in the middle of the night it will hang up the internet upload or download (no internet) but network still there and connnected. Reason for being skeptical i have probably a little over a week before I lose my return window. I'm happy if it continues to work fine on this lower firmware but afraid that after my return window I will have issues with newer firmware releases and I'm stuck with this. So i'm actually at a loss as to what to do. Seen some good reviews on the linksys ea9500 and the asus 5300. So I gotta really decide quickly whats the best thing to do as well.
Thanks for your assistance!
Yeah. If this is the case, I would do the same, returning the router, too , because one week is too short for any hesitation.
Asus has been excellent in their routers, particularly high-end ones. Their AC routers seems to be very stable ( My other 2-story-house
with ASUS RT-AC3200 works perfectly with covergage more than 3000 sqft).
Well, good luck for you then.
- windsagaJan 10, 2018NETGEAR Employee Retired
Hi DiRjDe,
Did you connect USB device ? I would like to know if uSB device let DUT crash and let sustem reboot.
System reboot let internet disconnect.....
- DjRiDeJan 10, 2018ApprenticeThanks Terry!
Hi Windsaga,
I did not connect any USB devices currently as my main concern was to have stable internet. After that I was gonna worry about adding a hard drive for network storage. - TerryPhJan 10, 2018VirtuosoHi DiRjDe.
Since you just downgrade to older version, and I don't have R8000P to confirm, can you
1. Confirm if the version you are running on your router has the Disney Circle feature on It?
2. If it does not have Circle parental control or anything involving Circle , can you let us know tomorrow if your router running stable. You have one week left to return if it gets "crazy"againππ.
3.FYI. Just received email from NETGEAR Production Manager confirming what I thought was the root cause of problems.... and they are working hard to debug it.
Thanks
Terry - DjRiDeJan 10, 2018Apprentice
Hi Terry,
I had to create an account access the parental side of the router settings. I just did and when i went to it I didnt see anything about disney controls - Here's a screen shot of it.
- TerryPhJan 10, 2018VirtuosoHi DjRiDe,
I assume that you created parental control account by DDNS account, if you don't have Circle, and this confirms that you are running older firmware version.
Please, please, please let us know tomorrow if any problems at all with the router functions.. This is also for my curiosity...
Thx
Hi Terry,
That is correct - thats what I had to create the account for. As of right now I'm still up and running with no issues on
Firmware Version
V1.2.1.6_1.1.86I put this on this morning around 9am - normally its about 48hrs to 72 hrs where I get the hang ups - will report back tomorrow (24 hrs) as well - just think its too soon to conifrm as well
- TerryPhJan 10, 2018VirtuosoGood to hear that. If by tomorrow you don't have problem, then chances are you will be ok. Let's just hope it will be stable until Sunday evening, that is way past 72 hours and still have few days left for return...
Best,
Terry - DjRiDeJan 11, 2018ApprenticeUpdate:
24 hours on:
Firmware Version
V1.2.1.6_1.1.86
So far no issues - internet hasn't went down - windsagaJan 11, 2018NETGEAR Employee Retired
Hi DjRide,
May I know your internet type? PPPoE or DHCP?
ISP is Arris ?
- DjRiDeJan 11, 2018ApprenticeWindsaga,
DHCP
ISP: xfinity/Comcast
Modem: attached - TerryPhJan 11, 2018Virtuosoπππ. I just wonder again if you can reconnect the SUB storage back to router. If it fails, there goes the router back to shop for return.
- TerryPhJan 11, 2018VirtuosoHi DjRiDe
πππ. I just wonder again if you can reconnect the SUB storage back to router. If it fails, there goes the router back to shop for return. - DjRiDeJan 11, 2018ApprenticeHi Terry,
I never had one connected but I will try one after I clear the 72 hour period. Just want to rule out that firmware is the only reason why the internet stops every few days. So far still good btw. Keep you posted. - aatareeJan 11, 2018Guide
I had the router locking / hanging issue during the month of december.
However, I installed the newest firmware the last few weeks and now i have no issues of needing to manually reset the router. You guys should give the new firmware a try.
It would be nice if netgear had a Router auto-reset function. Example: if the device does not respond to devices in 30 seconds, reboot the router.
Model R8000P
