cabchop's avatar
cabchop
Tutor
Jan 17, 2017
SSID and connection questions for R7800 Router with R7000 in AP mode
Current set up: Ranch style house with the two devices set up on opposite sides of the house.  R7800 acts as Main Router (one side of house ) and uses both 2.4 and 5 channels with seperate SSIDs.  On...
  • cabchop's avatar
    cabchop
    Jan 18, 2017
    Appreciate the insight. I suspect one would have the same issues with the latest mesh WIFI offerings as well?  Looking into the Orbi and others as they offer one SSID.   I've used the Smart Connect feature on the R7000 and seem to maintain quality speeds.  Unfortunately, the R7800 does not offer this feature.  I suspect I'm not alone in my quest for one SSID.
