JohnnyWB
Apr 27, 2016Tutor
Unable to do a fresh set-up wizard install on my Nighthawk AC1750
Ok, I just built a brand new computer, mainly to be used for gaming. My Ether cable runs from the DSL Modem to the Nighthawk Wireless unit, then I ran an Ether Cable directly to my new PC and pllugg...
- Retired_MemberApr 28, 2016
If they're greyed out that's a sign you're not in router mode? So the question is what mode is it in? Did you tinker yourself into an unknown mode?
Retired_Member
Apr 28, 2016If they're greyed out that's a sign you're not in router mode? So the question is what mode is it in? Did you tinker yourself into an unknown mode?
JohnnyWB
Apr 28, 2016Tutor
Now, thats the $64 Mill question. I just hooked it up, as I did my last computer, which was also on Windows 10, ran the Genie App and the set-up wizard, as before. I do not know what happened to it either. I know to being with, I had to redo my Nighthawk, when i fist got it but that was simple and had no trouble getting it to come up correct, that second time. Now, since i have built my own, it seems to be a problem and I am not sure why. I will keep looking myself and see what I can do on this end. Thanks.
- VE6CGXApr 29, 2016Master
Forget the Genie for the time being. Can you log into router directly using it's ip address 192.168.1.1?
