JohnnyWB's avatar
Apr 27, 2016
Unable to do a fresh set-up wizard install on my Nighthawk AC1750
Ok, I just built a brand new computer, mainly to be used for gaming.  My Ether cable runs from the DSL Modem to the Nighthawk Wireless unit, then I ran an Ether Cable directly to my new PC and pllugg...
  • Retired_Member's avatar
    Retired_Member
    Apr 28, 2016
    If they're greyed out that's a sign you're not in router mode? So the question is what mode is it in? Did you tinker yourself into an unknown mode?
