RogeRoje's avatar
RogeRoje
Follower
Feb 13, 2017
Ready Cloud Folder Not Available
Currently I am using a R7000 Night hawk Router. I have a ready cloud account and WD 1 TB external Drive connected. The folders are simply not showing when I log into ready cloud. I can see the volume on my network within my home...I can even access if through ftp and https if necessary, but the folders do not appear when trying to access through the readycloud. I have tried removing the volume, renaming the share drive and recreating it. I have even changed the name of the ready cloud accouint with a different email address...
  • Hi RogeRoje,
    Try to reset the router and reconfigure. Check again if the same. My R7000 is working with the ReadyCloud.
  • JamesGL's avatar
    JamesGL
    NETGEAR Employee Retired
    Hi RogeRoje,
    Unregister your account from the R7000 and  try to re-refister. Check if still the same. Make sure the router is on the latest firmware. Reset and reconfigure.
    • RogeRoge's avatar
      RogeRoge
      So....yes I have disconnected the account...and created a new account...I have the latest firmware also....I can try another account but I think the same results are still the same...I really need to get this resolved...
    • JamesGL's avatar
      JamesGL
      Hi RogeRoje,
      • JamesGL's avatar
        JamesGL
        Hi RogeRoje,
        We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
