eddietylam
Jan 29, 2016Aspirant
ReadyCloud Files Sharing for USB HDD users??
Hey buds. I am a new Netgear user with a R7000. Great interface, many features. I am loving everything with it so far. I just get a question with the ReadyCloud file sharing. I do registered ...
- Feb 03, 2016
ElaineM wrote:eddietylam That feature you seek is only available for ReadyNAS devices. It's not available on routers.
It just so happen that the interface centralized on both ReadyNAS and Nighthawk routers.
Through this is not good news, thanks for this clear official reply anyway.
eddietylam
duplicate thread, please refer to this one
- ElaineMFeb 01, 2016NETGEAR Employee Retired
It just so happen that the interface is centralized for both ReadyNAS and Nighthawk routers.
- eddietylamFeb 03, 2016Aspirant
- JitzeFeb 09, 2016Aspirant
OK, but how to understand the information given in http://readycloud.netgear.com/client/en/router-setup.html
- JamesGLFeb 16, 2016NETGEAR Employee Retired
Hi All,
You can share the folder by creating a web link.
1. Access readycloud.netgear.com.
2. Login your account.
3. Right click a specific folder and select "Create Web Link".
4. Before sharing the folder, you can select an option to create a password for the link and number visits.
5. After clicking the "Create button", you will now have the link.
6. When you click the link, you will be seeing the following:
a. Enter the password.
b. The files inside the folder you have shared.
c. You have the options to download the file.
