sclubone
Jul 07, 2016Aspirant
ReadyCLOUD icon invisible on Mac OS X menu bar
The menu bar icon for ReadyCLOUD is invisible when running El Capitan, it makes no difference whether dark mode is on or off. When will Netgear fix this? Or is there a workaround? I am running v1.3 o...
ElaineM
Jul 11, 2016NETGEAR Employee Retired
Hello sclubone
Welcome to the community!
We cannot replicate the problem you're having. We are using OS 10.11.5.
What's the OS version your running?
- scluboneJul 15, 2016Aspirant
Hi, I am also running Mac OS X 10.11.15. You will be able to replicate this problem by turning on the 'automatically hide menu bar' mode under General in System Preferences, leading to the problem as shown:
