sclubone's avatar
sclubone
ReadyCLOUD icon invisible on Mac OS X menu bar
The menu bar icon for ReadyCLOUD is invisible when running El Capitan, it makes no difference whether dark mode is on or off. When will Netgear fix this? Or is there a workaround? I am running v1.3 o...
  • ElaineM's avatar
    ElaineM
    Jul 19, 2016
    sclubone This has been replicated by our engineers. At this time, we do not have any ETA as to when it will be fixed but rest assured that they have taken note of this.
    Thank you very much for your feedback.
