Leos1
Nov 09, 2017Guide
ReadyCloud not working
I have USB drive connected to Nighthawk 8000 router. I used with Readycloud App on Ipad or via destop /web site.
Last several days I noticed that I cannot access this drive from internet. It used to work fine.
I still can access via https or ftp externally, but not with ReadycCloud App
Hi Leos1,
I have tried 2 iPhones here and it works. Can you try to unregister and register again the ReadyCloud account in the UI of the router.
- JamesGLNETGEAR Employee Retired
- Leos1Guide
Yes I can access it through web ,no problem. Only iPhone and iPad apps fail.
I tried delete and reinstall apps - did not help
- Leos1Guide
I have installed readycloud on 3rd device - new Iphone and the result is the same - can't access files on usb drive.
Still able to access through web, bit not through IOS applications
