VI86
May 08, 2017Aspirant
readycloud sign in error
Hi, I previously wrote about my ready cloud sign in problem, but I solved it updating the firmware. Now after 4 months I have the same problem again. I cannot sign in (user id and password do no...
- May 19, 2017
Hi VI86,
Change the password to a simple one like Password123 or other password with the same format.
JamesGL
May 10, 2017NETGEAR Employee Retired
Hi VI86,
Can you try to reset the router and reconfigure it manually.
What is the exact error message when trying to register the account via routerlogin.net?
- VI86May 11, 2017Aspirant
Thanks,
I already tried but It did not work.
Readycloud's Username and password are not recognized while I can log in from the web site but the router is not recognized.
Regards
Vincenzo
- JamesGLMay 19, 2017NETGEAR Employee Retired
Hi VI86,
Change the password to a simple one like Password123 or other password with the same format.- VI86Jul 20, 2017Aspirant
Hi,
I tried to chenge password and at the beginning router worked.
I did not use ready cloud for 1 month and at the moment I see router "online" just from the Iphone App. I trieb by web site, pc app, but nothing, my router is "offline".
Can you give me additional help?
Thanks
Vincenzo
- storm1985Jul 20, 2017ProdigyOn the router UI unregister then register again. Once done try to access readycloud not just on the browser but also on the desktop/phone ReadyCloud apps for isolation.
