kmboardman1's avatar
kmboardman1
Readyshare backup
I have used Readyshare Vault to back up to my USB drive in the past, however I see that is no longer supported, I signed up with Readyshare Cloud and can not find where the backup function is. I downloaded the Readyshare NAS and that does nothing for me. Can someone please direct me.
Thank you
  • michaelkenward's avatar
    michaelkenward
    Not without some l knowing of what Netgear hardware you own.
    Is this a router or an NAS of some sort?
    What do you mean by "backup function"?
    Where to find it in the browser graphical user interface?
    If you want the client for your PC or mobile device, try visiting the support pages for your hardware.
    Manuals are always a good place to start.
    Visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware.
    That page will also have any software, firmware and drivers for your device, if they exist.
    • kmboardman1's avatar
      kmboardman1
      Router R8000
      I have an old WD My Book drive attached to the routers USB.
      What I am asking, with Vault there was a back up tab, I don't see anything relating to backing up with Ready Cloud. Its says the Netgear will no longer support vault, so I dont want to use it any more.
      Support | NETGEAR
      Been there.
        michaelkenward
        Is this what you read?
        Support for Readyshare Vault ends April 15, 2021 | Answer | NETGEAR Support
        ReadyCloud and Readyshare Vault are two different things.
        Not sure what more anyone can say beyond suggesting that you look for an alternative backup system. There are plenty of them out there.
