rmccarro's avatar
rmccarro
Readyshare mobile "disconnected"
Hello, Quick question.  I have an R8500 with USB attached storage.  I can access via webpage remotely, no issues.  However, I cannot access my USB attached storage using android mobile app on my sma...
  • rmccarro's avatar
    rmccarro
    Jun 24, 2016
    ElaineM,
    Thank you for pointing out the firmware you were running.  The Netgear rep you forwarded me to (Joey) instructed me to update.
    To solve the problem:
    #1 - I updated the firmware with the built in router firmware update software to 1.0.2.64.
    #2 - The Tablet started to work right away.  No additional steps here.
    #3 - The phone did not.  I uninstalled and re-installed the Readycloud app to the newer version.  It then started to work and is currently uploading photos now.
    Not sure about the Iphone yet, but feeling pretty good this problem is solved.
    Thank you for your help,
    Richard
    Side note:  #1 Got out of work early today. #2 Fixed an 8" crack on the inside of my windshield, on the first try, with a tool I've never used before (Crackeraser).  Hmm, I wonder what the lottery is up to now-a-days.
