rmccarro
Jun 14, 2016Aspirant
Readyshare mobile "disconnected"
Hello, Quick question. I have an R8500 with USB attached storage. I can access via webpage remotely, no issues. However, I cannot access my USB attached storage using android mobile app on my sma...
- Jun 24, 2016
ElaineM,
Thank you for pointing out the firmware you were running. The Netgear rep you forwarded me to (Joey) instructed me to update.
To solve the problem:
#1 - I updated the firmware with the built in router firmware update software to 1.0.2.64.
#2 - The Tablet started to work right away. No additional steps here.
#3 - The phone did not. I uninstalled and re-installed the Readycloud app to the newer version. It then started to work and is currently uploading photos now.
Not sure about the Iphone yet, but feeling pretty good this problem is solved.
Thank you for your help,
Richard
Side note: #1 Got out of work early today. #2 Fixed an 8" crack on the inside of my windshield, on the first try, with a tool I've never used before (Crackeraser). Hmm, I wonder what the lottery is up to now-a-days.
rmccarro
Jun 22, 2016Aspirant
Thanks for your reply. I recently attempted connecting with Iphone 6s plus, w/o luck either.
Router Firmware Version:
V1.0.2.54_1.0.56
My Android OS (phone) is: 6.0.1
App version: 1.2.6
My Android OS (tablet) is: 5.0.2
App version: 1.2.7
My Iphone OS is: 9.3.2 (13F69)
App version: 1.5.8
Thanks,
Richard
ElaineM
Jun 22, 2016NETGEAR Employee Retired
rmccarro Thank you for the information. Interestingly, it's working with an iPhone 5SE (9.3.2), however, the firmware on my router is the latest 1.0.2.64.
Anyhow, I will forward you to one of our support personnel and they'll be in contact with you separately.
- rmccarroJun 24, 2016Aspirant
ElaineM,
Richard
- ElaineMJun 24, 2016NETGEAR Employee Retired
Glad to hear that it's now working and thank you for your update!
Sounds like you had a productive day.
Let us know if you need further assistance.
Have a great weekend!
