TimeoutService
May 09, 2016Aspirant
Readyshare on Windows 7
Right, well i want to install readyshare vault on my win7 pc but it can't even find my R7500 router. (setup as a AP). My Win10 laptop has no problem with it.. i closed down the firewall, the ant...
- May 24, 2016
Hello, yes i managed to solve this . the only thing i did was to give the windosw 7 pc a static dns 8.8.8.8 then reinstall the program. After it found the dtive on the router i reset it to automatic dns from router and it was able to keep the vault settings.
very odd if you ask me cos the vault is on local network but apperntly it tries to find it not through ip adres but through dns name, and if you have dns on your pc set to auto, it gives you the dns of the provider and of the routers gateway.
problem solved !
JamesGL
May 23, 2016NETGEAR Employee Retired
Hi TimeoutService,
Please provide us an update of your issue if you still need assistance.
- TimeoutServiceMay 24, 2016Aspirant
problem solved !
