jackvans
Jan 18, 2017Aspirant
ReadySHARE USB Printer
Where do I find the ReadySHARE USB Printer for macOS Sierra (Mac OS X 10.12)? I was here:
http://downloadcenter.netgear.com/?cid=wmt_netgear_organic#searchResults, but that vesion doesn' work.
Thanx for replies.
Welcome to the community, jackvans
Contact support and tell them that you need the compatible USB Control Center Utility for your Mac computer.
- jackvansAspirant
Thank you for your reply. Isn't that weird. Why should you a ask (beg) for software. It should be available on their download site. On the download site is only old OS X stuff.
- ElaineMNETGEAR Employee Retired
The software is under beta testing since the release of Mac El Capitan.
- Sui_GenerisAspirant
Hi there,
I can't seem to contact support without having to pay to support...
I would like to download the beta version of the USB printer Controller.
- frkirkAspirant
I too need the compatible USB Control Center Utility for your Mac computer with macOS Sierra. It won't even allow me to uninstall it.
