theherm
May 07, 2017Aspirant
ReadyShare vault doesn't recognise USB drive
I've bought a new R7000 and hooked up a Samsung M3 (2TB) USB drive. The router recognises the drive perfectly and works fine for accessing files through e.g. Windows Explorer. But, Ready Share V...
- May 08, 2017
Problem solved by de-installing and re-installing the ReadyShare Vault software!
theherm
May 09, 2017Aspirant
No, I only re-installed the Vault software. I think it is necessary to leave the USB drive connected while reinstalling. At least that is how I did it and I think was different from my first installation.
I had help from the Netgear helpdesk. Maybe try them otherwise. They seemed rather confident in solving the problem.
- swellerMay 10, 2017Aspirant
Netgear support just told me, "ReadyShare Vault feature is not supported by the C7000 device." and that I should go ahead and return it to the place of purchase. :-\
Putzing around with the software some more, I stumbled onto the fact that Vault can't get to the USB drive except through Genie. And Genie can't log in without manually entering the IP. For now at least, I have it working.
- swellerMay 11, 2017Aspirant
Never mind. It failed again. Are you sure yours is till backing up? My most common problem is that Genie doesn't recognize the router.
- thehermMay 12, 2017Aspirant
Mine is backing up while I type this. I noticed I first have to access the drive through ReadyShare and then navigate to the ReadyShare Vault, otherwise it doesn't recognise the drive. But it seems to work fine untill now.
