theherm
May 07, 2017Aspirant
ReadyShare vault doesn't recognise USB drive
I've bought a new R7000 and hooked up a Samsung M3 (2TB) USB drive. The router recognises the drive perfectly and works fine for accessing files through e.g. Windows Explorer. But, Ready Share V...
- May 08, 2017
Problem solved by de-installing and re-installing the ReadyShare Vault software!
sweller
May 10, 2017Aspirant
Netgear support just told me, "ReadyShare Vault feature is not supported by the C7000 device." and that I should go ahead and return it to the place of purchase. :-\
Putzing around with the software some more, I stumbled onto the fact that Vault can't get to the USB drive except through Genie. And Genie can't log in without manually entering the IP. For now at least, I have it working.
sweller
May 11, 2017Aspirant
Never mind. It failed again. Are you sure yours is till backing up? My most common problem is that Genie doesn't recognize the router.
- thehermMay 12, 2017Aspirant
Mine is backing up while I type this. I noticed I first have to access the drive through ReadyShare and then navigate to the ReadyShare Vault, otherwise it doesn't recognise the drive. But it seems to work fine untill now.
