turn00's avatar
turn00
ReadyShare Vault Software will not download.
Readyshare vault will not download.  It times out every time and says network error.  Is there anywhere else I can get a copy of this software?
Thanks
  • > [...] Is there anywhere else I can get a copy [...]
       "else"?  Are you offering any clues as to where you found the failing
    download?
  • michaelkenward's avatar
    michaelkenward
    And your Netgear device is? Are you trying to download from its support pages?
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware.
    That page will also have any software, firmware and drivers for your device, if they exist.
    Then there is here:
    download | Support | NETGEAR
    Is that where you had a problem?
