Jsuchii
Oct 02, 2021Aspirant
Recommendations to setup PC for 60Ghz wifi connection.
Hello!
I own a typical windows gaming desktop that comes with the usual pre-installed 5Ghz/2.4Ghz wifi card and would like to install a wifi card that supports 60Ghz wifi for gaming/streaming with my Nighthawk AD7200 Router. However, I'm not much experienced with what I specifically need for my computer but so far, I am aware I need an antenna and wifi card to install on my motherboard. I've been searching online for days but I've only been seeing 802.11ax wifi cards and no 802.11ad ones. Can anyone help? Thank you in advance.
wireless AD was a tech that really didn't catch on because of its low range. And its speeds dropped off quickly.
I know of a millitronic mg360 usb 3.0 device.
thats about all I know of
- plemansGuru - Experienced UserNot worth the price in my opinion. the $ would be better put to a decent AC/AX card.
- JsuchiiAspirantOh ok! It seems I should go for an AX router along with the wifi card instead. Do you have any recommendations for great ax wifi cards for gaming/streaming? Thank you in advance!
