aisorn
Dec 16, 2018Aspirant
red right only
What should i do , It only red light power on only
- Dec 21, 2018
You will need to contact support as there could be a hardware issue with the unit.
https://www.netgear.com/support/contact.aspx
DarrenM
schumaku
Dec 16, 2018Guru - Experienced User
- aisornDec 16, 2018Aspirant
no , sometime white light
schumaku wrote:
What should I do if the Power LED on my Nighthawk router stays amber and does not light white?
- shadowsportsDec 16, 2018Hero
Greetings aisorn,
Did you perform the reset procedure in the link schumaku provided?
Wat were the results?
3 possibe causes fo this behavior:
-Corrupt or incomplete FW
-Defective hardware
-Weak or defective power supply
If a reset doesn't work via the reset button, attempt to manually reflash the FW from a machine connected via ethernet. TFTP is built into windows 7/8/10. Please post your progress.
I have original power cord , I don't know , How to check defective hardware . I already reset many time .
shadowsports wrote:
Greetings aisorn,
-Defective hardware
