aisorn
Dec 16, 2018Aspirant
red right only
What should i do , It only red light power on only
- Dec 21, 2018
You will need to contact support as there could be a hardware issue with the unit.
https://www.netgear.com/support/contact.aspx
DarrenM
aisorn
no , sometime white light
schumaku wrote:
What should I do if the Power LED on my Nighthawk router stays amber and does not light white?
shadowsports
Dec 16, 2018Hero
Greetings aisorn,
Did you perform the reset procedure in the link schumaku provided?
Wat were the results?
3 possibe causes fo this behavior:
-Corrupt or incomplete FW
-Defective hardware
-Weak or defective power supply
If a reset doesn't work via the reset button, attempt to manually reflash the FW from a machine connected via ethernet. TFTP is built into windows 7/8/10. Please post your progress.
- aisornDec 16, 2018Aspirant
I have original power cord , I don't know , How to check defective hardware . I already reset many time .
shadowsports wrote:
Greetings aisorn,
-Defective hardware
- michaelkenwardDec 17, 2018Guru - Experienced User
OK. Slow down and do things methodically.
Your first message said:
"only red light power on only"
schumakugave you a link to a Netgear page on this. Did you read it? And what happened when/if you followed the instructions?
Then you said "sometime white light".
Which is it? "only red light" or "sometime white light"?
As shadowsports said, one way out of the hole could be this:
How to upload firmware to a NETGEAR router using Windows TFTP | Answer | NETGEAR Support
But you will have to be a lot clearer about what is going on, what you have tried, and what happened when you tried it.
- aisornDec 20, 2018Aspirant
my router stop connect with computer sometime . It won't connect all the time with computer , I do all process tftp upload . Please suggest me again
